LVSMT Series
12-35 kW | Three phase | 3 MPPTs
undefined
Low voltage
Latin
98.8%
undefined
undefined
undefined
Max. efficiency up to 98.8%
Full-load running at 50°C
String level monitoring
130% DC input oversizing
110% AC output overloading
PLC Communication
undefined
Low voltage
Latin
98.8%
undefined
undefined
undefined
200V-950V Wide MPPT Volatge Range
Compatitable with High Power Module
DC input current 15A
Modello
GW35KLS-MT
Max. tensione di ingresso (V)
800
6/2
Max. efficienza
98.0%
220, 3L/N/PE or 3L/PE
Modello
GW30KLS-MT
800
5/2
Max. efficienza
98.0%
Modello
GW12KLV-MT
800
3/2
Max. efficienza
98.7%
Modello
GW15KLV-MT
800
3/2
Max. efficienza
98.7%
Modello
GW20KLV-MT
800
3/2
Max. efficienza
98.8%
Rivenditore
Distributore
Utente finale
Altri
