2018-10-25
La serie di inverter SMT GoodWe: compatta e potente per una maggiore efficienza
La serie di inverter SMT GoodWe: compatta e potente per una maggiore efficienza-Notizie
The brand new three-phase inverter of the SMT series of GoodWe (25kW, 30kW and 36kW) is ideal for medium and large-scale commercial rooftop installa­tions due to its high power density, which includes up to three MPP trackers for harsh environments, a wide input voltage range for maximum flexibility and a perfect match for bifacial PV panels.
Rivenditore
Distributore
Utente finale
Altri
