2018-07-16
GoodWe Le serie NS, DNS, SDT, DT sono ora dotate di porta Ethernet integrata per il monitoraggio
GoodWe Le serie NS, DNS, SDT, DT sono ora dotate di porta Ethernet integrata per il monitoraggio-Notizie
All new generation GoodWe NS, DNS, SDT and DT Series inverters come equipped with factory-built Ethernet capability which facilitates integration into a local network. With an optional plug & play module, there will be no additional network setup required for the GoodWe Ethernet-connected inverters.
There are many benefits for connecting the GoodWe inverters to the internet, such as real-time monitoring, remote fault diagnosis, and easy access to GoodWe online platforms among many others. The built-in Ethernet port provides a direct wired connection between the user's network and the GoodWe inverter offering a faster, more secure and stable data transfer compared to Wi-Fi.
The optional plug & play Ethernet module is applicable for both home router and network switch usage.
Rivenditore
Distributore
Utente finale
Altri
